928 steering racks interchangeable?
Hi there fellow shark owners...
Having spend a couple of hours searching and reading here in the forum, it is still not clear to me.
Are the power steering racks on a 928 interchangeable?
I have a '89 S4 where one side of the steering rack is leaking. I could have it rebuild, but I do also have access to a rebuild steering rack from a 928 '78, complete with inner and outer tie-rods.
I know there is a difference in the overall length of the racks, but since I will be swapping the entire rack and tie-rods, will I then be able to use the one from a '78 on my '89?
Can I simply compensate for the difference in length by readjusting the toe-in?
Hope you guys can help me with this one, although it seems there are different oppinions. Bare in mind that I'm from Denmark, so ordering parts from the US is a bit costy.
Casper Schou
Casper Schou
You won't be able to swap the rack stops between racks though. Be careful.
So I've now taken of both racks and placed them along side each other. The overall length (rack + tie-rods) don't seem to be a problem. Only negative aspect of fitting the '78 rack is, that the turning radius of the car seems to increase.
Are the rubber boots (protecting the steering axel between rack and tie-rod) in each end the same on all 928? The ones on the racks I've got "look" a bit different from eachother, but the I meassure them to approx the same, although they are difficult to meassure. Searching the part-stores they only carry one type, but you would expect the new rack to have "longer" boots?
I'm guessing they are the same, but can somebody please confirm that?
Thanks everyone
Best regards
Casper Schou
Thanks everyone
Best regards
Casper Schou
