928 Forum 1978-1995
Sponsored by: 928 Specialists
Thermostat Replacement, '80 my
Old Aug 13, 2011 | 04:39 PM
joehelendetroit's Avatar
joehelendetroit
Default Thermostat Replacement, '80 my
Does the "Thermostat Seal" exist in an '80 my?
I plan on replacing my thermostat and already have on hand a new thermostat and O-ring. In reading the various posts here on Rennlist I have been lead to believe that there is a seal pressed into the water bridge and the thermostat seats against this seal. Recognizing that the car is nearly 32 years old, I would like to just order the part and have it on hand when I swap out the thermostat.
In an effort to identify the part I went thru the PET catalog, the workshop manual and 928 International's website and I am wondering if this part does not exist in the older cars. 928Int'l shows the part as being for an '84-95...
http://www.mailordercentral.com/928i...106%20163%2000
and there is nothing in the WSM....
File Type: jpg
Old Aug 13, 2011 | 04:52 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
your car doesnt have the rear thermostat seal it started in late 83/early 84
You only need a new thermostat and the O ring
parts 15, 16
Old Aug 13, 2011 | 05:28 PM
James Bailey's Avatar
James Bailey
You also need to be very careful trying to remove the two bolts...they break easily. So soak them with penetrating oil , heat them up with a torch before you try removing them.
Old Aug 13, 2011 | 08:03 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
use new bolts and put anti seize on them
