GTS transmission oil cooling system
Hello ALl
Would someone be able to post some pictures or links to show the same, to the GTS manual transmission oiling system please .IE the rear exit from the pump and the entry to the front internal spray bar please.
THanks in advance
THanks in advance
These threads have pics of various gearbox coolers including some good shots of the GTS spray bar:
https://rennlist.com/forums/928-foru...spray-bar.html
https://rennlist.com/forums/928-foru...lp-needed.html
The first link also shows where the factory welded on the spray bar mount on the '92 gearboxes (aka "early 93" in the US).
