Troubleshooting help for HVAC blower
On my 82 the HVAC blower does not work.
I swapped out the relay with a new since I tested it and it did not switch when power was applied. After replacing the relay it was still inop and a couple of days later it started to work. It worked for about two weeks and quit.
If I apply power to the blower directly it works.
If I jumper the relay it works. The fan speed selector works as well when jumpered. I have tested the new relay and it switches when pwoer is applied.
I pulled the CE panel and the connections are good and no bad wires.
Any suggestion as to what to check next.
Thanks Thom
Thanks Thom
Rennlist Site Sponsor
Connections on Fuse #17 - always a trouble spot.
Pull Relay XXI, identify Terminal 86. Turn ignition switch on, HVAC on, and check for battery voltage on Terminal 86 to ground.
I have no power to terminal 86. I read another post where someone replaced the window winder relay and it resolved the problem so I ordered a new seems odd but I will try it for a $7.00 part.
