LH Relay - grounding question (SOLVED)
Would my LH work in a 1993 GTS for checking purposes?
Can just uplug the harness on the GTS and then plug it into mine so i don't have to actually remove the existing LH unit in the GTS, the bracket is not a ground or anything?
I checked both the LH and EZK in my friends GTS and both the LH and EZK worked perfectly, together and separately.
So I doubled checked the wiring again to make sure it was 100% stock and no wires were broken, changed the relays again, cleaned everything again, dropped in a brand new bosch battery and…..it works!!!
Thanks everyone for your help.
