Will these rear brake rotors fit my 79?
I have looked several places and can't cross reference the numbers provided or find all the dimensions.
Part Brand: FTE/***
Manufacturer Part Number: BS 4144
Other Part Number: 44 352 041 02
Dimensions of rotors are: Outer Diameter 288mm; Height 100mm; Hub bore 100mm; Bolt Circle 5x130mm; Minimum thickness stamped on rotor 18.6mm
Part Brand: FTE/***
