928 Forum 1978-1995
Sponsored by: 928 Specialists
84 Grounding points
Old Aug 1, 2011 | 03:07 PM
dwc928s4's Avatar
dwc928s4
Default 84 Grounding points
Does anyone know a list or detail drawings of all the ground point locations for an 84 - 928s Euro A/T transmission.
Thanks.
Old Aug 1, 2011 | 03:22 PM
Landseer's Avatar
Landseer
Yes, I think so.
Go through this thread, though it gets off on tangents. Somewhere deep in the thread are some sketches that should help, in conjunction with the various pictures that cover most of them.
http://forums.pelicanparts.com/porsc...-16v-euro.html
I think the only ones I didn't show were in the driver's wheel well for the antilock unit.
Also under / behind the steering column (lay on back with head on brake pedal to see it)
Bat. ground strap under tool tray.
Beneath right rear quarter panel.
Right cam cover ( 2 critical ones!)
Just behind right cam gear backing plate
Front right of radiator on body
Front left of radiator on body
Left wheel well ( anti lock )
Under steering column
Block to frame ( under passenger side of engine)
Two sets of grounds on inside firewall, just above CE panel
I think that's it. Some folks have added later style coil clamp grounds and wiper motor grounds to combat radio interference.
Old Aug 1, 2011 | 06:56 PM
Dave928S's Avatar
Dave928S
It's worth going through the FAQ section at the start of this forum. Here's one of the posts with ground point diagrams to add to what Chris has already posted above ...... https://rennlist.com/forums/2220328-post33.html
Old Aug 1, 2011 | 07:08 PM
Landseer's Avatar
Landseer
Confusion sometimes is that one is specific for 86.5 and forward
Wish we could rebuild that thread.
Old Aug 1, 2011 | 07:43 PM
Randy V's Avatar
Randy V
25 Year Member
There is one located in the New Visitor FAQ topic located at the top of this forum.
Old Aug 1, 2011 | 07:59 PM
Landseer's Avatar
Landseer
unfortunately, it sucks because doesn't apply to his car, or anything else prior to 86.5, Randy.
How about opening up that thread so it can be updated?
Old Aug 1, 2011 | 08:13 PM
Dave928S's Avatar
Dave928S
I didn't notice that ..... I agree ... there are probably a few more things that could be added and updated on that thread.
