Oil in the A/C compressor
Team Owner
there are detailed instructions for adding oil quantities in the WSM,
Also you didnt provide any info on what parts you have replaced,
usually the 2 lines from the compressor should be replaced before you connect the system,
these can be rebuilt at any competent hose shop
If you are converting then you should flush out each component first the put the system together with fresh green O rings.
If you try to flush the system with it all connected then the O rings will be damaged from the flushing fluid sitting on every joint
Rennlist Site Sponsor
Quick answer is to drain the compressor and put that much OR a minimum amount. The amount varies with the type of compressor.
You also must change the receiver/dryer and add oil to the new one. Good practice calls for changing the old brittle O-rings to the new green or blue ones.
The only oil that you can use is POE.
Search is your friend - this has been discussed at length several times.
Location: Magnolia TX, just north of Houston, Red 1984 S
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
