88 S4 A/C repair...
So far I have identified that my A/C compresso and clutch have failed (not sure if anything else has) ... I dont want to do this myself so, how much to you think it is going to cost me to get them to purge the system, install the new A/C clutch and charge the system...?
91 F + high humidity in Miami, I need A/C// : )
About twice what it would be in January .....it really depends on what they do and what parts they insist on using. The hard part is they will not warranty very much unless they get to do everything they wish. You must do the reciever/ dryer most recommend a new expansion valve or two , the assorted seals are all too old to be reliable, and then there is the 134 conversion if not done already. The hoses to the compressor are also probably original....
