Exterior Temperature Display - Calibrate?
The temperature display on my GTS does not match actual temperature.
Is there anything that can be done to correct that?
Mine varies wildly depending on sun or shade.
I park in a garage at work and it will show like 85 when I leave for lunch, then if I park in full sun and get back in the car later it will be 110 or something (ambient is say 95) ...
My sensor is properly mounted (driver's side mirror). That was the first thing I checked when I was trying to resolve the issue.
The temperature reading will often show 10 - 20 degrees lower than the actual outside temp.
Other times it reads correctly.
Awesome - that would be great if you could.
randyv928 at gmail dot com
I'll then post the PDF to my web space and link it in this thread for others to use.
Thanks to Gary, here's the instrument cluster diagnostic manual:
http://members.rennlist.org/randy_v/...%20Cluster.pdf
What is the temp sensor located under the driver front fender in the hose going to the alternator.
