Power Draw Help needed
OK,
Per Wally's suggestion removed the three wires from the post and the battery stayed fine. Reconnected the 2 red wires to the post and it was still fine. I connected the brown wire to the post with the big connector not connected and it started drawing and voltage started going down rapidly.
I have the wiring diagrams but do not have a clue what I am looking for.
Any help would be appreciated.
Bilal
Bilal
Shameful Thread Killer
OK,
Bilal
Bilal
Now, if you have it broken down to one wire doing the loading, then leave that off, start the car and let it idle, then go through the systems one at a time, and check off what works, and what doesn't. i.e. Headlights, high beams, horn, heater, AC, radio, int lights, seat movement, mirror movement, etc. When you find what doesn't work, report back, and we may be able to identify the supply wire, and what may be causing the drain.
I am in CT. New Canaan CT. The wire I am talking about is the one that you disconnect at the post with the connector to do the WP/TB replacement. It is also shown on Dwayne's write up. So I know that I am connecting to the right location.
That is the main power feed from the battery / alternator up to the post, and it's RED! - then to the rest of the car !
So, unfortunately, you know the problem is back from there. I would go back to the CE panel and start trouble shooting. At this point, its better to pull the battery, unhook the big red wire, put a sensitive ohm-meter on the big red wire ( it should show a very low resistance) , and pull every fuse one by one, checking the resistance, if it suddenly jumps up, you are on the right track!
Team Owner
dont run the engine with any wires disconnected you will fry something else most likely the alternator or the engine computer..
NOW if your talking about connecting the brownish( actually was red) wire to the hot post then you may have a bad alternator that is internally shorted
Stan, he has no drain until he hooks up the big red wire - wouldn't that suggest the alternator is good as it is still in circuit, but the load side of the post has the problem?
So if this is the harness that goes to the panel, can somebody provide me with a picture or routing path. It could be that when I lifted the engine (by the home made 4x4 wooden brace) to replace the MM and when I set it back down I could have pinched this harness or nicked a wire and that is why I am getting a short?
Suggestions?
Bilal
Suggestions?
Bilal
Team Owner
the fat red wire goes to the alternator, if your showing a drain with this fat wire connected,
then you either pinched a wire when installing the alternator or it has an internal short .
anyway remove the alternator and inspect the wire harness with the rear cover removed
MrMerlin,
So if I take the alternator OFF, what am I looking inside once I take the back cover off? The buring plastic smell was comming from the other side of the engine. Also I checked the wiring to the alternator and it is not pinched. I was degreasing a lot of the stuff at the bottom of the car, some engine degreaser might have inadvertantly gone into the alternator as it was sitting on an upside down pail.
Bilal
Bilal
Before you pull the alternator:
As i said earlier, you do not look for a short by continually applying battery voltage - you may make it worse. Do you have a digital ohm-meter? I'll modify the steps I suggest:
1) Disconnect the battery.
2) disconnect the big red, which we have determined goes to the alternator.
3) Unplug the 14 pin adjacent to the jump post.
4) disconnect each wire at the jump post.
hook one lead ( black) from the ohm-meter to chassis. Withe the meter on the 1000 ohm ( 1k ) range, measure and record the resistance at the disconnected reed wire, each of the wires removed from the post.
Now, reverse the leads on the meter, so red is to chassis, and repeat.
Post back and i'll give you next steps....
Neil
Neil
