oil drian plug replaced with pipe bolt!
I am changing the oil on the 80 euro and took a closer look and found PO had welded a female tap on it probably due to cracking the pan.
I was looking to attach a socket and observed all the head was rounded and was made of brass.
The interesting part is it just unscrewed with my fingers.
Looking at some options:
Replace bolt with Rtv
Replace with Npt thread bolt to add washer if I can find one.
Pray.
My concern is with different materials is brass and aluminum will it loosen up over time. This car has 35-miles since the last oil change and the oil is way to thin, I was adding mobile-1 15-50 to bring up the pressure from 1-Bar when really hot!
Suggestions?
Pray.
Suggestions?
Wow is right, I am restoring this car for an acquaintance he bought it after 10-years sitting and less then 50-miles since it started running again. I can see the thread driving along lost all oil pressure, I just replaced the Dash Mylar good thing at least the lamps will come on!
I think the best approach is Black Rtv the bolt or plug does bottom out so it can be tightened. And no I am not going to replace the pan!! You should see the other stuff I found so called repaired by P.O. funny it only has 36K on it interior is like new.
Rennlist Site Sponsor
NPT (National Pipe Thread) is tapered.
It would not be practical to install a bolt-type plug, as it would be virtually impossible to get the threads tight at exactly the same time that the flat sealing surfaces mated.
You can buy a new brass plug at a hardware store, home center or plumbing supply.
Rest in Peace
Well Restore means reliable and daily drivable in my book!
You may have another definition but if everything works I mean everything what would you call it?
A full restore in some circles means like new or better, and who would do that to a 80 Euro non S?
So I guess as a purest you may cringe at the thought of not replacing the pan, it's not my car and not my wallet!
Rest in Peace
Vehicle restoration, the process of returning a vehicle to a like-new state.
That is far from that.
