Will I need spacers?
Hi,
I just bought some used cup wheels for my 82 S. The rears are 8" wide. Do I need spacers for them, and if so what size? I currently have 7" wide rims. The rims are 16" tall and the rears will have 50 series tires.
Thanks,
Joe
Thanks,
Joe
It all depends on the offset of your new wheels, with a high offset you might need spacers on the rear, but i doubt you will need them on the front as the 928 needs very high offset at the front (around 60)
Cheers
Cheers
Tell us what offset, widths and diameters the fronts and rears are, and what size and brand tyres you'll have on them .... example ..... 16" x 7" ET 65 with 225/50ZR16 'BRAND' would be a standard early front combination. I'm assuming that's probably what you have (standard disc wheels) front and rear now?
Measuring what clearance you have now will also be valuable additional information to determine what you'll have with the different wheel/tyre combinations.
1982 would not have had spacers.....Also if you run 50 series tire anything bigger than a 225 will be taller larger diameter and have negative effects on handling and acceleration. Your speedo will also not be accurate.
In ROW cars they were always just option even though they were very common. At late '86 MY ROW almost all cars got them. In all '84-86 about half of the ROW production had them and they might have been stock setup in some countries.
In US model they were optional and fairly common in early part of '84 MY. Around VIN 0450 they became standard and all US cars up to last '86.5 should have them.
