928 Forum 1978-1995
Sponsored by: 928 Specialists
Headlight linkage e-clips are 5/16"
Old 07-12-2011 | 03:06 PM
MainePorsche's Avatar
MainePorsche
Default Headlight linkage e-clips are 5/16"
Just a quick get for those who need to know.
Old 07-12-2011 | 03:24 PM
blown 87's Avatar
blown 87
Rest in Peace
Pretty sure they are a metric size, while that may work, that is not the correct size.
Old 07-12-2011 | 03:28 PM
hinchcliffe's Avatar
hinchcliffe
5/16 - .3125"
8mm - .3149"
Old 07-12-2011 | 05:12 PM
MainePorsche
Curt,
True 8mm was at the origin, but may be hard to come in places. The 5/16" does work just fine - a good snap to get on.
Old 07-12-2011 | 06:16 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
They are a good fit, I've used a few on several cars and they have been on for a long time.
Since the 8mm ones keep popping off, the 5/16s are a bit tighter and that can't hurt.
Old 07-12-2011 | 07:40 PM
jcorenman's Avatar
jcorenman
I used 8mm self-locking circlips from McMaster-Carr: http://www.mcmaster.com/#cad-2d/94824a400/=d5dsm0
Part# 94824A400, about $5 per pkg of ten. Fit fit good, and seem very secure.
They are just a black-oxide finish, so rust might be a problem in some areas.
Old 07-12-2011 | 11:47 PM
MainePorsche
24/10,000 of an inch smaller. I don't think the radiator demon will notice this one.
Old 07-13-2011 | 12:54 AM
blown 87's Avatar
blown 87
Rest in Peace
I have to speak up on this, and frankly that is why I have so much 928 work.
The whole, yea that is close enough, this will work, it is cheaper, I am only going to drive the car for a short time.
You ether do repair work to the best of your ability, which for some of us is perfection or as it was when it left the factory, or better.
Or, you can do what is easy, what is cheap and hope for the best.
Your call.
Old 07-13-2011 | 12:58 AM
whiteNSXs's Avatar
whiteNSXs
Thumbs up
Originally Posted by hinchcliffe
5/16 - .3125"
8mm - .3149"
The difference in size is negligible. I myself was in the situation of finding the clip missing. A quick trip to the local OSH got me these SAE clips and they fit perfectly. The fact that the factory clip is the one that keeps popping out tells you something.
Steve
Old 07-13-2011 | 01:45 AM
Speedtoys's Avatar
Speedtoys
Your call.
So...is better good, or bad?
Old 07-13-2011 | 02:29 AM
Tails's Avatar
Tails
I fitted a circlip to mine which give over 300 degrees clip securing into the groove and requires a pair of circlip pliers to remove it.
This is better that the "E" clip in my opinion.
Tails 1990 928S4 Auto
Quick Reply: Headlight linkage e-clips are 5/16"
