Interior Lights Delay on GTS
Looking at CE diagrams for GTS and not seeing the 928.618.225.01 relay that earlier models used to provide the interior lights delay. How is the delay done on a GTS?
I'm going to look at each of the three switches (doors and hatch receiver) to try to see if one of these has malfunctioned. I took the bulbs out of the red marker lights on the doors, and that has kept the battery from running down, but I suspect either a switch has pooped out or the relay/mechanism for the delay is kaput.
Problem started after I went into the doors to replace the door checks, so I might have disturbed a wire to the lights in there ... could that have made the lights stay on?
