Duc's Hybrid build
#121
right now I'm debating still on using the heads i got from england off a LH 16v and having them rebuilt, or using the set from early euro that i have done now.... anyone know if there is any real difference?
#123
Archive Gatekeeper
Oh the huge manatee, your TB is on backwards....
#126
Which crank dampener should be used on a hybrid, the orange one from the short block or the green one from the Euro S motor (to match the rpm characteristic of the cams)?
#128
heads
what part numbers can you give me and I can tell you what your valve timing is as there is 4 different sets .
look on the cam cyl bank and on the rear face of the camshaft
#130
the springs are different,the euro valves are larger,the compression goes from 8.6 up to 10 to 1 but that may be mostly the configuration of the piston crowns
#132
I think the engine is an interfence engine now. At least this is what Mark Kibot claimed. I am not sure why this would be the case, but Mark has more experience on this. If it is an interference motor then the 45 degree mark is important as is a belt tension sensor circuit.
Otherwise the Euro damper is probably the one to use. After all you are just increasing the displacement. The timing is still set by hand and a timing light. The marks on the Euro damper are probably worth while. The ones on the 5.0 are there for setting valve timing. Then again you might be using adjustable cam pulleys although setting the cam timing might not be the same.
Good luck
Good luck
