Shifting much better
Got the vaccum leak fixed changed the O2 sensor replaced all the exhaust bolts and gaskets new hanging rubber tightened up the heat shields I acually got the grommet for the O2 sensor thru the hole in the floor board changed the heater control valve pulled vaccum test on system. Now the car shifts much smoother and maybe a little too smooth 1st to 2nd great, 2nd to third great, 3rd to 4th a little slow or a little slip going to put it on a rack this weekend to check the fluid level and maybe adjust the modulator a little. The engine runs smooth as silk also and the a/c is much cooler. Any ideas about the tranny 1st shift at 2400 2nd at 3000 3rd at 2800. Thanks, Jack
