928 Forum 1978-1995
Sponsored by: 928 Specialists
GT engine into an S4?
Old 06-09-2011, 07:56 AM
Lizard928
Lizard928's Avatar
not sure that pitting will be worse on a slower idle. But the slower idle will not be a problem with those cams, they have no overlap!
Old 06-09-2011, 07:57 AM
John Speake
John Speake's Avatar
Originally Posted by Lizard931
But John,
Putting a GT engine into his S4 he would likely be using the S4 LH and therefor have the lower idle.....
Yes, but some people were advising fitting the GT LH EPROM....
Old 06-09-2011, 01:42 PM
Kaz
Kaz's Avatar
Originally Posted by Rob Edwards
Huh. I presume your '89 was white? Mark Anderson bought that wrecked '89 and I bought the GT engine out of it. It's now the stroker engine in my GTS. Did the shop rebuild the engine? It had an oil pan from an '83 on it, and the main bearings had been replaced before, when I pulled it apart.
The guy after you did a real number on that car.
Nice! Yes, the car was white and Mark did buy it. I let him know all I had done to the car while I owned it, Marcus Hutchinson had it before me. He used to be on the boards a few years ago, had that red wide body supercharged 928. One of the first. I recall Markus H. of GAA having some familiarity with the GT prior to it getting hit so it is entirely possible but I didn't hear anything other than "low mileage GT engine" and there was no rebuild from the time it left the GT and went into my engine bay. Part of the trade was my S4 engine block which turned out to be in great shape and I think went into a track car they were building at the time if memory serves.
Old 06-09-2011, 03:50 PM
928mac
928mac's Avatar
Mine is a 89 s4 from Japan and it has the GT stamp on its head, I do not believe (but not sure) it has the GT cams.
Drop it in and tune it if needed, I bet it will be fine.
Old 06-09-2011, 05:17 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,707 Likes on 1,310 Posts
Brad-
If you have GT cams, there will be an '01' stamping on the rear end of each cam, like so. If it says '00', then you've got S4 cams.
Old 06-09-2011, 08:51 PM
928mac
928mac's Avatar
Brad-
I think it was the 00 as you say. I don't think the PO changed them.
Old 07-21-2011, 12:31 AM
Asiandude
Asiandude's Avatar
Talking
I'll just resurrect this thread with the outcome...
The GT engine arrived in pretty poor (external) condition so I stripped it down and replaced all gaskets and seals etc. The water pump plastic impeller had separated from the shaft and just fell out! The GT cams looked fine so stayed in. The cam gears were as new but the plastic bushings in the tensioner arm were missing! The fuel dampers and regulator all leaked and injectors were clogged. Not too shabby then!
So the motor is now finished and in the car. Once the injectors were cleaned the car starts and idles very well, no problem with the S4 LH. Car seems quicker and smoother than before, or maybe I'm just kidding myself! The LH and MAF were rebuilt by Theo so that probably helps too. A few photos from the other side of the world then.
Old 07-21-2011, 08:41 AM
nc_growler
nc_growler's Avatar
Sounds like a complete success! Congratulations on your new GT (motor)...
Old 07-21-2011, 08:49 AM
Landseer
Landseer's Avatar
Nice follow-up.
Quick Reply: GT engine into an S4?
