Is the Pirelli PZero Corsa Directional?
Found a couple of 295s but they both say "right" on sidewall, so I am assuming they are both for right hand side and therefore useless to me. Right?
".... The P Zero Corsa uses a high hysteresis tread compound that transfers the vehicle's horsepower to a dry track by developing inspiring grip at high tread temperatures. This tread compound is molded into a unique asymmetric and directional tread pattern that features a sturdy outer shoulder to provide lateral stability and cornering grip, while grooves in the tire's central and inner tread areas enhance wet track handling and braking. The P Zero Corsa's asymmetric and directional tread design requires separate "left" and "right" side tires for the vehicle as branded on each tire's sidewall. "
Lifted from Tirerack.......
