Blinder M27 v/s M45
Correct me if I'm wrong but the M27 is front protection only and the M45 is front and rear. If correct then it's a no brainer. I got nailed about a year ago from the rear.
Paul, you dirty old man! I got caught speeding with laser from the rear. He was parked on an on ramp when I went by.
OK, you stick to that story. Although I do not utilize this term, out of respect to the law enforcement community, some might say a "pig" was involved, right? I stand by my earlier comment.
Rest in Peace
M27 has two sensors, M45 has 4 sensors, you can put them where you want.
Where do you mount on the front of a 928 since there really isn't a flat place to aim for, close to fog/driving lights?
Rest in Peace
Since I have made custom 1/8" x 1" T6061 aluminum brackets for the front grill, I can make or added extension bars as mount points. See picture below.
![](https://rennlist.com/forums/attachments/928-forum/535259d1305052168-so-what-did-you-do-to-your-928-today-p1010660.jpg)
IIRC AO has a binder on his car. The sensors are mounted on the underside of the top grill opening with custom aluminum brackets. When I finally get around to getting one for myself that's where I plan to mount the front sensors. The rear will go where the license plate lights are with the lights being replaced with a smaller LED light for the plate (maybe in the center between the two sensors).
