Rear AC lines, installing them with engine in car??
Rest in Peace
I thought I read a thread about some one who actually installed a rear ac lines with out pulling the engine.
Can some one help me find that?
Thanks.
Thanks.
Rennlist Sponsor
Greg,
It is easy to mount those with the engine in the car....
The only hard part is getting the KINKS out of those metal lines afterwards... HA HA!!
Seriously, I would like to see this thread too, never tried to cipher that hard on it and maybe it can be done.
See ya soon,
See ya soon,
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Rest in Peace
I am just trying to figure out if I should go ahead and start lifting the motor.
It HAS to be done by early next Friday, at the very latest.
Rennlist Sponsor
Rennlist Sponsor
Archive Gatekeeper
Perhaps it was this thread?
https://rennlist.com/forums/928-foru...C+removal+line
I only managed to R&R the high side line's rubber section, which in retrospect could have been done in situ. Not sure whether the suction line could be done with the engine in.
Rest in Peace
Yea, that was it Rob, so let me just get this straight, you were able to get the lines in and out with the engine in the car?
With a lot of trouble I am sure.
Archive Gatekeeper
Yes, but just the high side line. I didn't try to R&R the low side line.
Greg,
I am liking the idea of adding a couple of o-ring unions to those two lines, if you can find a spot that is both accessible and also allows the top and bottom halves to be removed without too much drama.
Ideally you want to keep the number of connections to a minimum, but serviceability is important also, and there are lots of o-rings already.
Here's the link that Rob posted, looks like they have some useful stuff: http://www.docsblocks.com/products.asp?cat=19
Good luck!
Good luck!
Rest in Peace
The high pressure line is in, but the low pressure line is not going to go in with the motor installed and the line in one piece.
I think I have a plan though.
Big Tom will be riding in the cold if it works out.
Rest in Peace
Greg,
Good luck!
Good luck!
Here is what I plan to do, on the cut up low pressure tubing there is a weld fitting that I can sweat off, then I can do the same with a nut fitting on one of the lines coming off the compressor, (that one will be toast, but you got to do what you have to when time is short)
It looks like the factory used some sort of silver solder to retain the nuts and fittings on, I got one of the weld fittings off today, and I will try to get the nut off on Monday, if that all works out well, then I will have the fittings to allow me to cut the line and put a union in it.
I have high hopes this will work.
Sadly we are having to use used lines, but they were holding on the 89 they came off of, so lets hope it will hold freon.
