Early 928 to 944 Head swap
Euro in the US is supposed to be federalized, cats added and various other bits, so its likely making less power than the same year US model setup from the factory to meet US standards.
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
IIRC they are not evenly spaced out, some lobes are closer to center than others with this combination.
One difference I remember is the valves on the EuroS head hare further away from the wall of the combustion chamber (valves closer together). The 944 head a lot more crowded (with the same size valves).
Todd made a comment he could fit a larger valve in the EuroS head than the 944![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
So with the modified 944 head you have unshrouded the intake from the bore by 3.5 mm. That is very important for flow and the exhaust valve just in case some are wondering doesn't need anywhere as much clearance from the bore. These engines can make really good power when the factory parts are optimized and then mated to a really good exhaust. Preferably with a bypass valve.
