AC charge steps final sanity check - update - I have AC!
#61
Been doing it at least that long, and even taught it some. Trust me. The sight glass is an OK indicator but far from the best way to charge. You are correct that a perfect system will be just at the bubble point there when it's working perfectly. But while you are standing in the driveway with the engine idling on a 75º ambient day it may be "just right", the same charge will not be "just right" for idling in 100º conditions with high humidity, or at 3000 engine RPM in any ambient condition. The expansion valve "adjusts" for most of this, but only based on evaporator pressure(temp) not for the high-side conditions where you have the sight glass.
Take a peek at the Mollinier diagram for R-134 and notice that it has a big 'knee' and in fact doubles baclk on itself slightly. Toss a couple darts at the chart, and tell me what the one perfect bubble-point condition in the system should be that will be perfect anywhere else on the chart.
Lots of folks have worked on these systems for years, and have a conceptual working knowledge of how they should work and what seems to work for them. But there really is some serious science behind it all. Really!
