top end refresh parts list?
Searched but could not locate, anyone have a link to parts needed/recommended for top end/intake refresh?
THANKS!
THANKS!
This was for my 87 S4 auto
Part Number Description Qty
928 110 713 01 & 928 110 714 01 Gasket Set - Intake Side Cover (L&R)" 1
928 110 580 02 Gasket - Main Intake Manifold 2
928 110 637 04 Gasket - Intake to Throttle Housing 2
928 110 160 00 Intake Flap Actuator 1
928 110 694 01 Intake Rubber Pressure Ring (seal ring for intake bolts) 10
928 606 161 01 Idle Stabilizer Valve 1
911 606 141 00 Knock Sensors (87-90 only) 2
928 110 663 00 Hose - Brake Venturi "Y" to Brake Booster 1
928 107 445 02 Hose - Right Front Cam Cover to Oil Filler (87-92 only) 1
928 110 432 02 Hose - Right Rear Cam Cover to Right "Y" at Air Guide Elbow 1
928 107 313 02 Hose - Right "Y" at Air Guide Elbow to Oil Filler (87-92 only) 1
928 110 224 00 Hose - Left "Y" at Air Guide Elbow to Brake Venturi 1
928 110 174 09 Hose - Left "Y" at Air Guide Elbow to Idle Stabilizer Valve 1
928 110 633 00 Hose - Idle Stabilizer Valve to Throttle Body Bushing (intake manifold hose) 1
928 107 603 00 Hose - Throttle Body Housing to Oil Filler & Evap Vent Valve 1
928 110 220 00 Hose - Left Intake Side Cover to Brake Venturi "Y" 1
928 110 014 01 Hose - Throttle Body Housing to 5- or 7-way Rubber Splitter 1
928 110 441 03 5-way Splitter at Rear of Intake (5-speed only) 1
928 110 441 02 7-way Splitter at Rear of Intake (Automatics only) 1
928 110 222 01 Air Guide Rubber Elbow 1
928 574 717 02 Small Rubber Elbow for Rigid Vacuum Line 10
N 020 139 1 Rigid Vacuum Line (2 meters) 2
928 110 430 01 Rubber Cap for Flap Actuator Bearing on Top of Intake 1
928 110 904 00 Fuel Injector Seal Kit 8
928 107 303 07 Oil Filler 1
928 107 307 00 Gasket, Oil Filler (87-95 only) 1
944 105 501 05 Timing Chain Bilstein 2
944 105 501 05 Timing Chain Iwis 2
944 105 501 05 Racing Timing Chain Iwis Racing 2
944 105 949 00 Top and bottom tensioner pad 2
928 104 447 09 Cam/Valve Cover Gasket 87 to 95 2
928 104 115 02 Valve Cover Bolt Thrust Ring 26
900 123 144 30 Cam/Valve Cover Sealing Ring 26
928 104 443 08 Spark Plug Seal 8
900 174 056 40 Breather O ring 4
928 105 215 00 Camshaft End Seal - Updated from 928 105 205 00 6
928 104 116 00 Valve Cover Bolt Thrust Washer 26
928 106 227 00 Water Bridge Gasket 2
999 701 627 40 Water Bridge O Ring 1
930 110 388 00 Injector Clips 8
999 701 632 40 Thermostat O ring 1
928 106 163 00 Thermostat Housing Internal Seal 1
928 106 129 17 Thermostat 83C Wahler 1
NA 87 to 95 EFI Fuel Hose Kit 1
NA 87 to 95 Wire set - Black or Red 1
928 602 211 01 Distributor Cap 85-95 32v 2
928 602 213 00 Rotor Cap 85 to 95 2
NA 87 to 95 Vacuum Hose Set - Red, Black & Blue 1
NA Fuel Pressure Gauge 1
928 606 157 00 Throttle Position Sensor 87 to 95 1
944 606 170 01 Hall Sensor 1
944 606 115 00 Crank Position Sensor 1
0 261 210 002 Crank Position Sensor - Alternative 1
928 606 126 00 Temp II Sensor 85 to 95 1
928 602 060 99 Beru Ignition Wire Set 87 to 95 1
na Economy Wire Set - Red or Black Beru 1
Something like that... a few items are duplicates or alternate choices
I just called Roger and said, send me the complete intake refresh. Everything I needed showed up. Figure on spending a grand or so not counting powder coating.
Roger sent the spreadsheet to me, I checked off what made sense I thought but the total came to over $2400! Sound right??
Yup.
Make sure there are two of these:
928 106 167 01
..you will need ONE under the heater outlet from the back of the head on the pass side, and ONE under the block off plate that you end up loosening up (cracking the gasket) on the drivers side.
I believe..that was the ONLY thing I was short, and I suggested he add that 2nd gasket to his list.
Thanks Gus..
Roger is working on the list for me now. Contemplating also putting in some of the reently recommended 19lb injectors as well... Thoughts?
Kenny,
Are you going with the 19lb Ford injectors, or sending the current ones off to WitchHunter http://www.witchhunter.com for testing and refurb?
Have you considered the Ford 24lb injectors and a Sharktune instead since you have already started modifying the exhaust?
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Kenny,
Have you considered the Ford 24lb injectors and a Sharktune instead since you have already started modifying the exhaust?![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Would prefer to go ahead and order the parts needed instead of sending off in order to avoid downtime...
Kenny,
agreed... This is gonna be enough of a project (and expense!) all by itself. Still contemplating on doing the new silicone hoses in red or black...
Heck, buy the Ford injectors, put them in while you send your origionals off to be rebuilt. When they come back, if you are not satisfied with the Ford ones, replace with your now rebuilt ones. They are very easy once you have done it a time or two.
matt930s (12-10-2020)
