AC compressor mount bolt torques?
I don't see the mount or the compressor to mount bolt torque values in the demensions and specs manua and the copy of the WSM I have is missing the AC section.
Standard TQ for the M8 bolt is 20NM and for the M10 bolt 40MN (WSM). Will these work?
Yep. Use those.
The default torque rule is kind of frustrating as you can't be sure it's not in there and you just haven't found it. The little "Tech Spec" booklets are nice for this as the torques are organized better.
