928 Forum 1978-1995
Sponsored by: 928 Specialists
torque tube thoughts
Old Apr 26, 2011 | 08:45 PM
wildwestsydney's Avatar
wildwestsydney
Default torque tube thoughts
I was thinking about the torque tube set up lately and thought to my self what if the propeller shaft was hollow like a standard drive shaft, a hollow large diameter shaft that ran thru the tube unsuspended by bearings. I could easily see cutting the ends offa stock propeller shaft and turning up a couple of sleeves to mate up to say 3” OD .065” wall drive shaft tubing and welding it up. Now you would have a torque tube to couple the motor to trans axle and a bearing less drive shaft running thru it. I kind of think that would be a neat way to drive the transaxle. I think it may be lighter than the stock drive shaft. Feedback, or thoughts.
Sam
Old Apr 26, 2011 | 09:26 PM
James Bailey's Avatar
James Bailey
The larger diameter driveshaft would then act as a flywheel making shifting more difficult. Plus the clutch and short clutch shaft would all need to be supported. Probably simpler to use all the Corvette stuff
Old Apr 26, 2011 | 09:40 PM
wildwestsydney
Yeah I did not take into account for the short shaft not being supported. Ok Bad idea.
Sam
