Lost wheel lock key
Lost wheel lock key
I was changing out the rear spacers and I think i might have driven off without removing the wheel lock key, I just can't find it.
Are they all the same?
Try a search - has been discussed numerous times with multiple solutions.
The best solution is to remove the wheel lock nuts and throw them in the trash. The only person that they ever deter is the owner.
I think you are correct, i will just delete them and replace them with regular lug nuts.
Team Owner
take a drill and drill out the center of the lock its brass and once this is done you can remove the cover then throw those things away
