86.5 turbo boost issue (dropping after 4k rpm)
Yep, at the back of the car.
Captain Obvious
Super User
Super User
Yes if your standing facing the car the left (passenger side) boost tube blew apart upon throttle lift on the way back to John's. The BOV just doesn't seem to be blowing off very rapidly, even more evidence of vacume issues.
Re:top end refresh. Cool. I plan on burning a chip tonight where I am at now and then we can finalize after the top end refresh.
One thing's for sure, between Mike and Sean............... I'm going to have 1 well sorted Turbo very shortly!!
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Pele is running the same TIAL BOV I am and mine works fine. It has a nearly 2" (50.5mm) piston. But, the vacume line running to it is probably to small. I used a full size 1/4 inch metal line for most of the line on my car and then used rubber just at the ends. My BOV did not activate quick enough with the smaller line I originally used and also where I had it tied into. I had to tee the BOV directly into the same vacume source I was using for my boost reference which on my S4 is a line running directly to the manifold, not any of the other accessory vacume lines to the HVAC/Fuel Dampners etc. The spring pressure inside the BOV needs to be an 11PSI spring to work properly with our engine vacume level. Need to check that too.
