How to install those *M^F#G fuel injector rails hold-down bolts ......Redneck method
Don't have a magnetic tool to start the nut on the bolt?
Or,
Did you also install the 3/4" pipe insulation like Dwayne showed and now you have zero visibility from above the bolt?
No worries!
Chew gum and pack some into a short 10mm socket. secure nut on gum and attach a long ext like this.....
![Name: photo(2).jpg
Size: 73.1 KB](https://rennlist.com/forums/attachments/928-forum/527453d1302519431-how-to-install-those-m-f-g-fuel-injector-rails-hold-down-bolts-redneck-method-photo-2-.jpg)
![Name: photo(3).jpg
Size: 59.6 KB](https://rennlist.com/forums/attachments/928-forum/527454d1302519447-how-to-install-those-m-f-g-fuel-injector-rails-hold-down-bolts-redneck-method-photo-3-.jpg)
Works like a charm.
If you're making other connections before moving on to the other rail now is a good time to remove gum from socket.
Throw used gum away
Or,
No worries!
Works like a charm.
Throw used gum away
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I installed the insulation like Dwayne showed, so I guess I'm going to have even more problems. I think I'll cut a peice out to make it easier to get to the stud. Thanks for the tip.
I put anti-sieze inside the socket to hold the nut in the socket.
I use a small piece of paper towel and cover the socket opening, then press in the nut or bolt.
The added thickness of the paper is enought to hold the nut or bolt in the socket, paper comes off when the nut or bold is started.
DaveK9
DaveK9
