Braided clutch line?
Curious, searched different permutations to see if any posts discussing replacing the clutch hydraulic hard line with a braided steel one as many other cars do and came up with zip.
Would seem with the snaking in and out of the hard line when replacing it or changin out clutch master cylinder, etc. a braided line would be much simpler.
Is there a reason this would not be a good idea on a 928?
There was a post from someone in CA who was rebuilding a car from the wheels up for his son. They did replace the two piece rigid and flex line with a one piece braided line provided by 928 intl (IIRC).
This maybe it.
http://www.mailordercentral.com/928i...0077%2007%20SS
This maybe it.
Last edited by hacker-pschorr; 04-06-2011 at 11:17 AM. Reason: Fixed the broken link to 928 International
https://rennlist.com/forums/928-foru...reshen-14.html
I think this is what you are looking for - see post #207 (there is a photo of the line). I checked with 928 Intl, and they were running $195 for the line and fittings.
I would really like to do this, but with other 928 expenses looming, I can't really justify at this point.
Dave
Dave
Hi Dave-
Jim should put his picture back up 'cause it illustrates the whole length of the cable and how it works with a stock S4 slave cylinder. Jim's is the configuration that Mark sells (linked below) but Greg can also make up different configurations for hybrid S4-dual disk setups like mine.
The plug-n-play version is available from 928Intl for $129.
The stroker engine has a 3/8" thick pan spacer on it, which necessitates using an early slave cylinder (whose inlet is angled differently vs. the S4 slave cylinder) and a banjo bolt connector for clearance. Greg Brown made up the flexible hose out of a bunch of Goodridge fittings that interface with the hardline at the swaybar bracket and at the slave cylinder. In between, it just zip ties to the starter wiring harness.
The goodridge line is actually cheaper than a new factory line..
Hi Dave-
Thanks,
Dave
Dave
