928 Forum 1978-1995
Sponsored by: 928 Specialists
Another wheel offset question
Old Mar 28, 2011 | 03:51 PM
87 Shark's Avatar
87 Shark
Question Another wheel offset question
I have just purchased a new set of wheels for my 87 S4. The fronts are 8Jx18ET50 and the backs are 10Jx18ET65. Front tires are 225/40/18 and back are 265/35/18. Fit is no problem and I will look for a 10to 15mm spacer for the back wheels. My question is can some of the increased offset for the fronts be compensated for with a new front end alignement?
Old Mar 28, 2011 | 04:03 PM
Cosmo Kramer's Avatar
Cosmo Kramer
Front end alignment will help, but that offset will present some handling issues. I had the exact same combo and sold them because the tramlining annoyed me.
Old Mar 28, 2011 | 04:38 PM
AO's Avatar
AO
Supercharged
Did you sell them to a guy named Dave in Manotick, On?
Old Mar 28, 2011 | 05:08 PM
Cosmo Kramer
Not unless he owns a S/C 996!
Old Mar 28, 2011 | 06:40 PM
87 Shark's Avatar
87 Shark
He would have bought them as he did not know about the offset/handling issues.
My old rims were 7.5x17 ET52 front so I'm hoping no difference in handling.
Old Mar 29, 2011 | 10:35 AM
Cosmo Kramer
The narrower rims seem to have less negative effects running a lower offset on the front. I went from 18 x 8 et 50 with 225's on the front to 17 x 7 et 55 with 225's and the difference was significant. Try them out and see what you think, lots of 928's out there running 996 wheels.
BTW on the back I was able to run 275's with a 21mm spacer and still have 1 cm clearance to the fender.
Old Mar 29, 2011 | 03:40 PM
87 Shark's Avatar
87 Shark
Thanks or the info. I did not notice a problem with my old set up. The car ran true after a good alignment. I am using the motorsports upper control arms and all seems OK for now. Thanks again.
