928 Forum 1978-1995
Sponsored by: 928 Specialists
Intake ONLY removal check list
Old Mar 18, 2011 | 01:52 PM
Koenig-Specials 928's Avatar
Koenig-Specials 928
Default Intake ONLY removal check list
To replace my flappy. I've removed (major stuff only):
1) The MAF and associated wiring and vac hoses and stuff.
2) Both fuel rails (I'll also install the Ford injectors I got from Roger)
3) Accelerator bracket & attachments on the driver's side of intake
4) Loosened the manifold hold down bolts
So before I try and lift it off......is that it? I'm double checking that I don't have to remove the oil fill equipment or water bridge stuff in front. Correct?
I'm also replacing the WOT switch. Is this a straight install or is there any little tricks so that after I re-install everything I'll hear the functional 'click' to tell it's working. Nothing wrong with the one in there now but it's old enough to require replacement. ISV is only 2 years old.
Old Mar 18, 2011 | 02:06 PM
the flyin' scotsman's Avatar
the flyin' scotsman
valve cover hoses, ISV wiring, tps wiring etc...........no need to remove oil filler or water bridge.
Old Mar 18, 2011 | 02:57 PM
StratfordShark's Avatar
StratfordShark
That 3 way hose which connects to oil filler neck and I think the divertor valve for fumes? Otherwise you wont be able to lift intake more than an inch or two.
Throttle cable needs to come off the ball joint at quadrant under intake.
Old Mar 18, 2011 | 03:31 PM
jeff spahn's Avatar
jeff spahn
just check out dwaynes' write up on his site about intake refresh. all pictures and everything and it will tell you all you need to know. 20min of reading and you'll be an expert
Old Mar 18, 2011 | 07:18 PM
Koenig-Specials 928
Thanks Guys. Dwayne's writeup was for the entire job. I used it as my bible when I did the TB/WP job a while back. Now I'm only going in to replace an unhappy flappy.
Yeah, I completely forgot about the throttle cable and the oil fume line to the oil filler neck.
Now I'm good to go, will be a late night in the garage. It's only 6 degrees C, so it feels like summer here in Ontario. Go figure.
Old Mar 18, 2011 | 11:24 PM
the flyin' scotsman
its was +3c here today.....some were out without jackets.....only a +25c temp change in 2 weeks
good luck with the intake, I just got mine off, again!
Old Mar 20, 2011 | 01:08 AM
RPetty's Avatar
RPetty
Im starting my sons tomorrow
wish me luck..
