928 Forum 1978-1995
Sponsored by: 928 Specialists
coolant warning
Old Mar 16, 2011 | 10:26 PM
fastduck's Avatar
fastduck
Default coolant warning
The coolant warning illuminated this afternoon after the master caution light came on. Coolant level is fine, car was not overheated, seemed like reasonable pressure in tank.
Shouldn't the warning go away off if I play with (short) the level sensor leads?
Thanks,
John
Old Mar 16, 2011 | 10:37 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
no the warning will not go away,
you need a new sensor,
there is a resistor in the sensor so just putting the wires together will not send the right signal to the warning control unit
Old Mar 16, 2011 | 10:39 PM
jthwan22's Avatar
jthwan22
Isn't the level sensor NLA? I have the same problem
Old Mar 16, 2011 | 10:54 PM
fastduck's Avatar
fastduck
Thank you Mr. Merlin - I've read your repair sequence/parts list to another list memb. in 2008, thanks for that too of course.
jthwan22: I see prices on the AutoAtlanta website for the sensor, haven't yet tried Roger or 928Intl.
John
Old Mar 16, 2011 | 11:06 PM
928 at last's Avatar
928 at last
Default I think
I think I saw some units on EBay lately........you might want to have a look.
Old Mar 16, 2011 | 11:23 PM
sweet928's Avatar
sweet928
928 Specialists has them for my 79. I just ordered one last week.
Old Mar 16, 2011 | 11:25 PM
jthwan22's Avatar
jthwan22
So it is not an open/closed switch? What is the resistor value?
Old Mar 17, 2011 | 12:33 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
take one apart and see,
then order a new part.
It has been in my experience that fitting used sensors is a good exercise in how the RnR the coolant bottle as usually the new used sensor is also bad
