Just put on 18 inch sport edition cup 4s
#31
They are on without spacers for now. I went to carquest and picked up some open ended lugnuts, but they turned out to be to big, needed 22 mm socket to tighten them and that wouldn't fit in the cup 4 lug holes.
I called a few other places and they directed me to Discount Tire, they said they would have something that would work. They had open ended lugs that were much smaller and longer lugs that require a key to put them on. They are designed to let the lug bolt punch through the end of the nut if the nut isn't long enough. They turned out to be perfect!
#33
https://rennlist.com/forums/for-sale...-for-sale.html
Make me an offer!
![](http://forums.pelicanparts.com/uploads17/2010+03+21+19+47+061269840951.jpg)
#34
Mark, it looks to me like when the 15mm spacers I sent arrive (probably tomorrow) and if they fit without rubbing, as we hope, you can get another set of these same nuts and put them on without punching the bolts through the tops for a nice chrome finish showing.
Jerry Feather
Jerry Feather
#36
Jerry, my wife informed me the sapcers just arrived. Thank you again! i will try them this evening and see how they fit.
Since you won't let me send you anything for shipping or your time, I am donating $20 to red cross for the Tsunami in your name.
#37
Mark, that is interesting about the long nuts. Now, I wonder if the original nuts might be long enough with the new 15mm spacers I sent you. After all, these spacers that I modified for you are only a quarter of an inch thinner that the 21mm spacers you have taken out. I still hope that is enough to keep them from rubbing, but still put your wheels out where they look like they fill up the wheel wells.
As to the cone nuts versus the round bottom ones, I don't know what happens. I wouldn't want to drive the car much over about 120 mph with cones in it versus round, but I am not sure why.
Jerry Feather
Jerry Feather
#38
Thanks Mark. You are my kind of guy. Jerry Feather
#39
Team Owner
Mark you should not mix the seating of the lugs to the wheels,
if you do you may damage the wheel collets permanently and destroy the wheels.
Jerry very nice of you to make parts for yet another enthusiast,
its good your here to assist others,
your very kind with your time and effort
#40
Jerry Feather
#42
The extra-long lug nuts in this thread are not right for our wheels. Porsche wheels use a spherical seat and those are conical. This mis-match could lead to cracking or deformation of the wheel.
#43
I am looking at these wheels also, but in 17" with 225/45 front, 255/40 rear. They seem to be a great price......But then I'll probably want to paint up the calipers and put cross drilled rotors on. So much for a cheap upgrade.
