Wireharness Question
Quick question regarding the engine wire harness. There is a ground on the passenger side which is secured under the passenger side M8 bolt of the "pulley bracket". On reassembly, I noticed what appears to be a second ground wire, but I can't recall where this goes. While any ground point would probably work, I would like to put things back together per spec.
If I had to guess, I think that it goes under the drivers side M8 bolt on the "pulley bracket. Any thoughts / confirmation on position would be excellent.
Thanks,
Dave
Thanks,
Dave
