Denver CO alignment recommendations
Does anyone have a sugggestion for and in alignment shop in the Denver area?
I am going to do ball joints, sterring rack RR, and tie rods and will need an alignment when done.
So any suggestions on where to go to get the job done right would be greatly appreciated.
Thom
Thom
Team Owner
I had a 928 aligned at Brakes Plus
IIRC it was on Dry creek just west of I 25 by about 2 miles
They lifted the car on their first attempt, but I stayed to watch and explained to them that it could not be lifted. After I drove it a hundred miles I brought it back and they aligned it correctly.
I think it was about $70.
Matt
I am at 58th and Wads so stop by on your way, or stop by any time. I will be in the garage this Friday afternoon and Saturday replacing a carbon canister, bleeding brakes and replacing a windshield washer tank.
Matt
Team Owner
Thom RV means well,
since your not known here,
this bit of info is meant to save you much grief further down the road, it is common for a shop to lift the front end to CHECK out the parts,
this will negate your alignment, so now you know this.
