Throttle circular cam?
Hi,
Is one of you has tested a circular reference cam instead of the progressive OEM one? It is the cam just near the throttle body wich control the position of the throttle in regard of the position of the gas pedal!
Thanks for your advice
Best
Puyi
Best
Puyi
OK,
Seems that none has ever tried that or may be, my question was not so clear.
I wonder how improve better gas pedal response. The fact is that the gas pedal has to be push for more than 20 mm in order to get good engine response. Seeing the OEM design of the control cam of the throttle, I saw that "progressive" design and wonder how we can change it for non progressive response but linear response.
Thanks for your opinion
Best regards
Puyi
Best regards
Puyi
