any engineers out there.custom drive plate,converter to flange.
uncovered more butchery while thying to put in the converter.someone gound the rivits off of the drive flange in order to move the positioning to use a different converter.i now have a gap of 9/16 between the converter and drive flange.my thoughts are to make an aluminum spacer plate to make up the difference rather than try to remove the flange and try to find another converter or flange.how much if anything would this affect performance?thanks
Careful. We're talking 6000 rpm at a pretty big distance from center. My guess is any plate you mention is more like a circle with a hole in the center. That could be lethal.
I think what you are talking about is the rear flex plate. I can envision someone grinding the rivets out in order to seperate the rear clamp from the plate, but I don't know why they would need to. Nevertheless, if that is what happened, what you need to do is gain access to the front flexplate and clamp and simply release the clamp there. Then go to the rear and pull the shaft back enough so the the ring/grove around it lines up with the hole for the bolt in the rear clamp and put it back together.
Of course you are going to need to obtain suitable bolts to fastens the rear clamp back to the center of the rear flex plate, but I con't think that will be a problem.
Then go back to the front and tighten the front clamp. While you are in there (the front) you might want to check the crankshaft end play.
No engineering and no fabrication required, in my opinion. Jerry Feather
In some MY (87?) rivets were used which tend to loosen and rattle around. The fix was to replace the rivets with bolts. Jerry might be right the front flex plate needs to be loosened.
no,the plate that bolts to the tourqe converter.the converter that was in the car is different than the replacement.the center hub does not go in far enough and will not aloww the plate to sit flush on the converter.there is a 9/16 gap.my plan is to make a plate the identical shape as the input shaft flange and use longer bolts .
Which rivets were ground out? Is the rear flex plate still riveted to the clamping piece with the flange. Is the 9/16 inch gap simply between the three points of the flex plate and the new converter? JF
If the plate you are referring to is the flex plate, and if it would move back far enough to contact the converter at the points of the flex plate, are there holes in the new converter that will line up with the holes in the flex plate, or are you going to have to make some kind of adapter to bolt the flex plate to, and then bolt the adapter to the converter? JF
I take it to mean that "three bolt stands" refers to something welded to the face of the converter that has threaded holes in them for bolting something to it. The question is, do these "stands" have two holes each and do they line up with the holes in the three corners of the flex plate, notwithstanding the 9/16 gap????? Or are they different from the holes in the three corners of the flex plate?????
What you are calling the drive flange must be the rear flex plate. Let's see if we can start to talk the same language on the project. JF
