lsd assembly
The Contact pattern should be centered on the tooth, Ring and pinion gears are a match set, and you can’t change just one part. That pattern looks too high.
... I've tried to be helpful, as have others, on the recent LSD thread you started in relation to how to do this ... but you've ignored all that and done it your own way anyway. It begs the question ... why ask how to do it correctly in the first place?Here again is why you need to do it the right way.
The LSD spool may not be exactly the same dimension as your original centre and therefore the bearing preload may be too much or too little. The position of the ring gear face on the LSD spool may not be exactly the same as on the original centre and therefore may not be in the correct position in relation to the pinion to give the correct backlash, and replicate what the factory set as silent running position.
You need to use the WSM procedure to determine the shim total ... then calculate the shim total thickness to give correct bearing preload ... then alter arrangement of total shims to give correct backlash (taking into account factory backlash measurement marked on the ring). It is very likely you will need different shims to get the total thickness correct and achieve the right side to side arrangement.
If you don't use the correct procedure it won't be right.
There is more than one way to skin this cat.
Set the diff in the case so the ring and pinion mesh. Use shims on the left to get it to track right
Use the right cover with no shims. Crank the right cover until you have zero lash. Run the diff over with an imprint. Adjust the left shims until it is right.
The right cover will now be off from case. Measure that distance and that is your shims for the right side.
This will be the easiest way to got the lash correct. Using dial indicators is a real pain
What Errka said ....
Here's an extract from the WSM ... and all the detail you need to get it right is detailed in that section of the manual ... it's not all that difficult. You have to take measurements.
I think as a minimum when you have it on the bench in front of it's worth taking the LSD apart, cleaning every component and inspecting for wear, replacing plates as necessary, lubricating every part and re-assembling ... then doing a torque test.
I got lucky with a secondhand LSD and it didn't have significant wear, which I found after I went through the dismantle, clean, lubricate, re-assemble and test process. If you don't know the condition of parts inside it doesn't make sense to just put it in the case. It could be totally worn out, or have debris in it which could trash bearings or gears.
