928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine badge
Old Feb 17, 2011 | 11:43 AM
R.Pires's Avatar
R.Pires
Default Engine badge
Hi,
I have the original chrome badge (928 110 403 00) in top of the engine, but I don’t know what the PO did that besides it being not correctly aligned, it is glued with some super glue or something that drains to the sides of the badge! It really looks ugly!
I would like to replace the badge with a colour one, but I can’t find a reference number and besides that the glue is completely hard and strong like a rock! What do you recommend to remove the old badge and where can I find a colour one, because I believe that for the engine with all the heat produced, we can’t use a “normal” Porsche badge, right?
Thanks in advance for your tips!
Regards
Old Feb 17, 2011 | 11:47 AM
Ducman82's Avatar
Ducman82
Veteran: Air Force
i just ordered a extra hood badge from Roger. works like a champ.
File Type: jpg
Old Feb 17, 2011 | 12:03 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
take a torch and heat the badge it should pop right off once you get it hot, have a fire extinguisher handy incase you ignite fumes
Old Feb 17, 2011 | 12:07 PM
R.Pires's Avatar
R.Pires
That looks excellent, that's just what I want! A normal hood badge will resist the heat of the engine? Wouldn't it start peeling or something?
Regards
Old Feb 17, 2011 | 12:10 PM
R.Pires's Avatar
R.Pires
That's a good idea! I don't have a torch but I have a friend who does!
Hopefully he knows how to use it, specially because it's my car.....
Thanks again for the tip Mrmerlin|
Regards
Old Feb 17, 2011 | 05:55 PM
Hold On's Avatar
Hold On
Same here. Used a nice enamal hood badge. Just snip off the studs and file smooth. Has held up very well for last year on a very warm S/C car.
Old Feb 17, 2011 | 06:32 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
It does not get THAT hot on the intake. if it does, you have other issues. i used Epoxy to attach mine.
Old Feb 17, 2011 | 07:32 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
to remove the studs on a new hood badge get a soldering iron and heat the stud base till it falls off, this should not damage the other side of the badge
Old Feb 17, 2011 | 08:45 PM
Griffinroydonald's Avatar
Griffinroydonald
I have a hood badge I would trade with you. I would like the one on the engine you have now. The badge I have has no pins on the back and is very nice. You can remove the badge on your engine by taping it with a very small screwdriver in the front. Please let me know if you can get your badge off without damage.
Old Feb 18, 2011 | 02:07 PM
Hold On's Avatar
Hold On
In Phoenix in the summer, with two electric fans pulling air past a radiator and a warm supercharger plus elevated intake temps, it gets warmer than usual. I wasnt implying I had any other heat issues.
Old Feb 18, 2011 | 02:10 PM
Speedtoys's Avatar
Speedtoys
True..but its not THAT hot.
Old Feb 18, 2011 | 02:37 PM
R.Pires's Avatar
R.Pires
Hi,
What I have is this one:
http://www.mailordercentral.com/928i...asp?number=928 110 403 00
It's not expensive and you will be better served with a new one, mine it's not looking nice that's why I want to change it.
Regards
Old Feb 18, 2011 | 02:56 PM
Hold On's Avatar
Hold On
lol No......its 112.......but its a dry heat!!! .....
