928 Forum 1978-1995
Sponsored by: 928 Specialists
1989 S4 auto transmission problem and install GTS shell
Old 02-11-2011, 02:20 AM
vinyl_tien
vinyl_tien's Avatar
Default Thanks
Thanks~~ Working on it now..
Originally Posted by karl ruiter
I am having shifting problems with my S4 as well. I am thinking mine may be a B2 piston problem. Search here for B2.
Old 02-11-2011, 04:30 AM
Tails
Tails's Avatar
When the B2 piston fails you usually loose all forward gears and retain reverse, so I personally do not believe that your porblems are related to the B2 Piston as you still have all forward gears. FWIW I do not believe that it is necessary to go into the action of the B2 piston and it application within the gear box at this juncture.
I have had a B2 piston failure and replace the B2 piston myself and all has worked satisfactorily ever since (The failure of the B2 piston is a known fact by MG as they have modified the B2 piston to a better design).
I wrote a report on its replacement of the B2 piston and posted it via 3 pdf files on this forum with pictures.
In addition, I was suffering from harsh gear changes and made up a union and pressure gauge and fitted it to the modulating pressure port and reset the modulating pressure to the correct specification value at idle in "D" and it now works as smooth as silk during gear changes.
Too low a modulating pressure will cause "flaring/slipping" between gear changes.
Tails 1990 928S4 Auto
Old 02-11-2011, 08:39 AM
vinyl_tien
vinyl_tien's Avatar
Hi Tails
I just finished your report also show them to my tech man.That is amazing. I will ask them to replace B2 parts for me, then see how it work.
Thanks!
Old 02-11-2011, 09:06 AM
Landseer
Landseer's Avatar
Roger has also access to the parts and there may be new part numbers for those pieces, when I did it using Taills (excellent) writeup they had changed slightly.
There are a wide range of lengths of actuator pins possible for getting B2 clutch setting correct.
Setting modulation pressure with gauges and seems like an important step --- a rebuild should include this step and a new modulation valve. A little firmer modulation pressure adjustment might solve yours.
Old 02-11-2011, 09:44 AM
ROG100
Basic Sponsor
ROG100's Avatar
Hi Tien,
I have the flair spring and B2 valve in stock and can add them to your order if your tech decides he needs them.
Roger
Old 02-13-2011, 11:30 AM
vinyl_tien
vinyl_tien's Avatar
Thanks Roger, please receiver PM.
Here is the first tome my tech man replace for me, but I have no idea what these for.. Can any one tell me?
Quick Reply: 1989 S4 auto transmission problem and install GTS shell
