Top End Refresh done!
All appears well so far..way better than before.
Passed smog too! (was big issue before)
But....I'll post #s tomorrow, didnt pass by far.
And I went thru the parts receipts..and I bought I think the wrong thermostat.
What known, documented effect, does a too low thermo have on emissions?
If engine temp is held too low, it may produce more soot, no?
They always make sure the car is properly warmed up at the test station.
Congrats on the smog, glad to know that intake refresh can do the job on that.
You suck. My parts are still at Powder Coater. Probably won't get the car done until I get back from vacation in March. Not that I can drive it with all the salt on the roads but still . . .
Have you replaced the plastic Y-connector in the passenger side front wheel well?
It joins the lines for the emissions carbon canister, and is a common failure. New one costs about $4 from memory.
What failure mode do you see when thats busted?
you smell fuel inside the cabin when driving. its like $10. I changed mine 3 months ago. If you don't smell fuel vapors inside, go outside to the passenger side front wheel and try to see if you can smell fuel vapors from under the fender. I could smell it after I had driven the car or while driving, so drive it around then check for the smell. I was told its not important to change but I guess the smell of fuel vapors could be harmful for your health.
"this thread is wortless without pics"
Alright Jeff..I know you'll be at NASA this weekend and I am planning on visiting Saturday....so I hope to see that fancy powdercoated intake installed in person!!!!
Bill Ball and I are going to rub baby harp seal oil over it for good luck Friday afternoon on the way up.
I'll get you a ride in the slow *** Pontiac too.
The vacuum solenoid line is from a hole just past the throttle plate, so when you open the throttle, it gets vacuum and opens.
In addition, the line from the charcoal canister to the intake has a solenoid controlled by the LH which is activated based on temperature IIRC - once the engine is warmed, the LH will pulse the canister to suck gas vapors captured by the cylinder into the engine.
With a broken Y-connector, when the engine's warm and you're not idling, you thus have an unmetered air leak.
Idle speed shouldn't be affected, as at idle the throttle plate doesn't expose the vacuum line for the canister's valve (assuming stock vac line configuration).
edit: simple test would be to run the emissions test with the vac line to the canister valve disconnected and capped. If you're still injured that may be easier
When you're cruising, the thermostat most definitely does control the engine operating temperature.
It's good to have the correct one in, as that will reduce fuel consumption a little.
What temperature thermostat did you buy?
