928 Forum 1978-1995
Sponsored by: 928 Specialists
Cooling fan problems
Old Feb 6, 2011 | 04:13 PM
Paul Bakker's Avatar
Paul Bakker
Default Cooling fan problems
Hello,
Last summer I had a problem with my cooling fans. When AC turned on one of the fans always went full speed.
After some searching (fuseholder, fuses, wireing) I got myself a new controlunit (928.618.418.00). Replaced it and everything worked fine. After a few months again the same problem got back again
Does anyone has an idea what could be the problem here?
Ofcourse I'll examine it closely next spring but I'm curious if anybody has a clue.
Thanks,
Paul
Old Feb 6, 2011 | 04:58 PM
shadowknight's Avatar
shadowknight
I believe the passenger side fan is supposed to kick on when the AC is running. Here is a good guide on troubleshooting the HVAC: https://www.928gt.com/t-wallyhvac.aspx
Old Feb 7, 2011 | 01:20 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Both fans should run at the same time. If only one fan runs, the first things to check are the fuses (one for each fan) and the battery connections.
Old Feb 7, 2011 | 05:09 PM
Alan's Avatar
Alan
Electron Wrangler
Further - whenever the AC is on both fans should run...
Alan
