Toothed Belt Covering with Cam Sensor
I'm having problems trying to communicate the need of a 32V Aluminum Toothed Belt Covering from a late model that has the mounting hole for the Cam Sensor.
Attached is a picture of earlier 32V Toothed Belt Coverings without the Cam Sensor.
Anybody have a picture of the passenger side cover showing the cam sensor mount from the front side? Or even the cover from the back side without the sensor installed?
Thanks!
Thanks!
Supercharged
I think you mean Hall Sensor which was installed on all 87+ cars. The covers are a fairly common part. I'm sure if you're looking for one, 928 International has them by the pallet.
