928 Forum 1978-1995
Sponsored by: 928 Specialists
cat bypass issues
Old Jan 27, 2011 | 11:36 PM
firemn131's Avatar
firemn131
Default cat bypass issues
Hey gang.
I just picked up a set of cat bypass pipes for my 87 928 s4 auto.
they are in the shape of an "H".
here is the issue..
the cross over in the H is just a spacer tube..there are no openings. so basically they are straight thru pipes..there is a dummy O2 sensor hole in the cross-member...will the car run ok with no inputs from the O2 sensor?
Has anyone ever used these before?
Old Jan 27, 2011 | 11:43 PM
cfc928gt's Avatar
cfc928gt
The crossover should be open, what makes you think it's not?
Old Jan 27, 2011 | 11:47 PM
firemn131's Avatar
firemn131
I put air in it and capped the ends..nothing came out the center port...Apparently the H and O2 port were put in to fool an emissions inspector...If I bolt it up< can I just put the O2 sensor on one side or the other?
Old Jan 27, 2011 | 11:56 PM
928 at last's Avatar
928 at last
Where did you source those?
Old Jan 27, 2011 | 11:57 PM
cfc928gt's Avatar
cfc928gt
That's really pathetic. Yeah, put it in either side. You might want to consider an X-pipe, it will give you lots more power. IIRC, those H pipes were only 2" tubes which are smaller than the stock pipes.
Old Jan 28, 2011 | 12:02 AM
firemn131's Avatar
firemn131
It was given to me...I am not too worried about more power,,,I want it to see if i like the sound better, and i want to do away with the cats...I have heard a few stories about the cats getting so hot that fires have started. I will dive into the car in the next few months and am planning my maintenance..
Old Jan 28, 2011 | 12:19 AM
928 at last
Seriously, Give 'em back and go for a proper "X" pipe setup. You can get high flow cats too. The fires are usually the result of "Operator Error" thinking there's a limp home mode. Read up on here about it. Search is your friend.
Old Jan 28, 2011 | 09:42 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
those pipes may not fit your it looks like an extension was welded on to the right pipe a test fit would be good B4 you remove your old cats,
The 02 needs to read the ex gas, if not your may not run well
Old Jan 28, 2011 | 06:11 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
I have the same looking one (less the extension) but the corssover pipe is open to the exhaust. However the air tube was a dead end.
Old Jan 28, 2011 | 08:19 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
+1
Also, take a look at the FAQ at the top of the forum, a lot of good knowledge in there:
https://rennlist.com/forums/928-foru...questions.html
Old Jan 28, 2011 | 08:30 PM
Leon Speed's Avatar
Leon Speed
Those look like somebody's home brew. Get a real x-pipe (or take this one apart, cut some holes and weld it together).
Old Jan 28, 2011 | 08:40 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
That's not a home brew. At least one of the big 3 used to sell them before the X hit the market. If it was home made, the balaning pipe wouldn't be oval and it's unlikely it would be all mandrel bent pipes.
Old Jan 29, 2011 | 04:52 PM
James Bailey's Avatar
James Bailey
The extention was probably to fit it to the 85-86 stainless manifolds when fitted to the 16v heads....since it moves the three hole flanges one side forward and the other side back. So I doubt it will fit your car as it is.
