Replaced Throttle [Pedal] Cable: WOT is fun!
Almost Deleted
I just finished replacing the throttle pedal cable [from go pedal to throttle linkage] cable. Great googly moogly!! WOT is fun!
I made sure everything was connected correctly and snugged up [made that mistake once], then took it on a drive. I made sure and drove it with care until it warmed up nicely. I went around a corner and punched it just for fun and subsequently lit the tires up and turned sideways. Wow. Just wow.![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Thanks Roger for helping source the parts!
Sure is fun isn't it
Craic Head
Just make sure you check the car again fully warm to make sure your idle switch is resetting. Mine was so close when it was cold that it wouldn't click back when the car was fully warm and expanded just that slight bit.
So cool when you find something relatively simple that makes a big difference in the ride.
