928 Forum 1978-1995
Sponsored by: 928 Specialists
rear shock replacement
Old Jan 19, 2011 | 11:16 PM
86shark928's Avatar
86shark928
Default rear shock replacement
Been driving around lately and driver side rear fender well sounds like the tire is rubbing; however it isnt. Kind of sounds like a clunk noise as or corner hard or hit a bump. I am thinking the shock needs to be replaced. Anyone have any idea how much the labor should cost to change out a shock if this is indeed the issue?
86.5 928
Old Jan 19, 2011 | 11:21 PM
AO's Avatar
AO
Supercharged
It should only take an hour or so, but the rates can obviously vary from shop to shop.
However, if it sounds like something is rubbing but it's not, it could be brake related or possibly wheel bearing related. I suppose half-shaft u-joint could also be suspect.
Depending on where you are in Texas, you might consider taking it to "SeanR" here on Rennlist. I think he's in Dallas.
Old Jan 19, 2011 | 11:23 PM
jeff spahn's Avatar
jeff spahn
+1 for Sean
Old Jan 19, 2011 | 11:32 PM
fraggle's Avatar
fraggle
If they've never been replaced, budget for a set. You won't believe the difference in ride.
Old Jan 19, 2011 | 11:54 PM
IrishLegend's Avatar
IrishLegend
+1, Sean is in the DFW area and he is very reasonable! PM him.
Old Jan 20, 2011 | 11:59 AM
Tom in Austin's Avatar
Tom in Austin
+ some more, Sean will get you straightened out in no time, plus will let you know what other things your car needs. Make a list and leave it with him for a week, that's the best way if you can work it out ...
Old Jan 20, 2011 | 04:16 PM
86shark928's Avatar
86shark928
thanks everyone, I have contacted sean already. Just had no idea what the going rate was before I stepped in anywhere.
