928 Forum 1978-1995
Sponsored by: 928 Specialists
The Gaps..hood and trunk..
Old 01-16-2011 | 03:28 AM
Speedtoys's Avatar
Speedtoys
Default The Gaps..hood and trunk..
Is it just me, or does it just feel like something should be in the gap between hood and bumper, and hatch and rear cover as well?
Old 01-16-2011 | 03:47 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
there is a beading thats installed
Old 01-16-2011 | 04:29 AM
Speedtoys's Avatar
Speedtoys
The 'piping' as its called..there is none in those places...only down the edges of each.
Old 01-16-2011 | 04:30 AM
Nicole's Avatar
Nicole
Cottage Industry Sponsor
Not on the S4 and later models.
Old 01-16-2011 | 05:27 AM
Hilton's Avatar
Hilton
If the gap's excessive, you can adjust it. The rubber stops on the lower corners of hatch and hood are adjustable and can be screwed in or outwards until the gap is even and likes up with the other panels.
Old 01-16-2011 | 07:05 AM
jon928se's Avatar
jon928se
As Hilton says yuo can adjust the height of hood and hatch by adjusting the rubber stops - Caveat you should also adjust the hood lock and hatch lock to suit.
However I suspect you are referring to the horizontal gap. You can slide the hood forwards by adjusting the hinge bolts at the rear until the corners of the leading edge of the odd are nearly but not quite in line with the leading edge of the fenders as they meet the rubber piping between fender and front PU.
At the rear I don't think you can adjust the horizontal position of the hatch. However be aware that the rear PU seems to sag downwards over time and you can't fix this either.
Quick Reply: The Gaps..hood and trunk..
