They will probably fit, but you will need a ~5mm spacer with those 60mm offset rear wheels. Also, you may need to pull out the rear fenders just a little, but that is quite easy since they are steel.
What do you think as to the front size should I go with 225 or 245, what's your take on this I can't decide. I'm kinda afraid that 245 on a wet surface would squeak when turning
