Intake Manifold Gasket
Just doing an intake R&R I was wondering if I should use a selant in addition to the rubber gaskets or do the gaskets seal well without any additional sealant
Sean
Sean
Team Owner
gasket seals go on dry
Team Owner
Note if your doing the intake i would add some Honda Bond to the oil fill spout O ring and the base, this part will leak due to the plastic parts melting or bowing,
the Hb should add some seal to the O ring, also consider getting the 928INTL oil fill block off plate
